JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
9505 Duel Ele
Old 12-31-2012, 07:02 PM
MX240
MX240's Avatar
Default 9505 Duel Ele
How do I program two elevators servos?
I have tried the flaperon and normal wing types.
By mixing ele with Aux 2 or Aux 4 I can get it to work but....no trim on one elevator.
This plane also has flaps so I need them also.
Old 12-31-2012, 07:09 PM
BuschBarber
Default RE: 9505 Duel Ele
ORIGINAL: MX240
I assume you mean the JR 9503? Like the 9303, the proper way to set up Dual Ailerons and Dual Elevators is to set the Wing Type to Normal and use the Mate parameter to specify the channel you wish to Mate with the Right Aileron and/or the Right Elevator. If you plan on using the Ailerons as Flaps, then you would choose a Wing Type of Flapperon.
Old 12-31-2012, 07:18 PM
Len Todd
I had the same problem with my DX8. There was a setting that activated the trim on the mixed control surface. On the DX8, that setting was in the mix settings. Not sure where you find it on a JR. The other option is to mechanically set both servo's linkages correctly and matched (i.e. where no trim is needed.). I typically go back and mechanically set the linkages so that no trim is needed,, once I maiden and get an idea where they need to be. That way you can use different transmitters w/o worrying about having to retim, etc.
Old 12-31-2012, 11:29 PM
codimasta
My Feedback: (89)
Try this:
Hook up 2 Servo Elevator
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3.
NOTE: You may have to REVERSE AUX2 OR AUX3 or both depends on the hookup of the linkage.
NOTE:
Connect the Elevators Right Elevator to Elevator and Left Elevator to Aux3.
Old 01-01-2013, 05:55 AM
BarracudaHockey
BarracudaHockey's Avatar
Rich is correct, using mates is the only way to get the trim to follow.
Old 01-01-2013, 06:59 AM
MX240
MX240's Avatar
Ha, Thanks a bunch guys...you were all a great help. Now it works.
But, how/where do you find this "mate" thing?
Using two channels for the ailerons it's "mate" would be??
Jim
Old 01-01-2013, 08:59 AM
codimasta
My Feedback: (89)
When using the DEVICE SELECT you are using the MATE function.
Dual Ailerons:
Hook up 2 Servo Aileron non Flaperon
roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2.
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2.
Old 01-01-2013, 09:08 AM
MX240
MX240's Avatar
OK,
Thanks COD for that information.
Now I think I am getting the hang of it.
Everybody have a good flying New Year ahead.
Old 01-02-2013, 07:15 AM
grizzly59
grizzly59's Avatar
The attachment will show a good start of inhibiting switche3s in Device select and then going to Wing type to mate surfaces for ailerons and dual elevater.
File Type: pdf
Old 01-02-2013, 08:11 AM
MX240
MX240's Avatar
Thanks for that,
I copyed it off and put it in the book and I am sure it is already in the book (maybe) but I sure didn't see it.
