JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Trim offset memory function
Old 09-15-2003, 02:48 PM
BigBird1
Default Trim offset memory function
Hey Danny,
I have a XP8103A...and have a 'lil question...
Is their a Trim offset memory function?
All I have is a display the says "monit" with the word trim under it..and shows how far off from center the trim is...after reading the manual many times and running the battery down once trying to find out how to center the trims via the screen, I've given up..
Is their something I'm doing wrong..or what?
Any help would be appreciated...
Michael
Old 09-15-2003, 03:16 PM
GBR2
Default RE: Trim offset memory function
With the 8103, you don't need to re-center the trims. Once set, the Tx remembers them for each of the 10 plane/heli/glider slots. The Monitor screen is just that and nothing more. A bit useless I thought but it is there. If it truly bothers you that the trim position is not right at the center, you can always mechanically adjust the control surface to stay the same as trimmed after you have moved the trim indicator to center.
Old 09-15-2003, 03:32 PM
dsnyder
dsnyder's Avatar
If you have the digital trim version of the 8103, the trim offset is no longer included as it is no longer needed. The trims are automatically stored for each model, eliminating the need for trim offset.
Old 09-15-2003, 04:48 PM
BigBird1
Thanks to be both of you...
I have the digital trims...
Thought I was going nuts..but guess not...
At least hey could warn you in the manual...[8D]
Michael...
