PCM 9X II compatibility
Hi everyone, I have a JR 9X II with pcm capability and have just bought a jr rs12da rx and cannot match the tx with the rx. Are these compatable with each other as on the reciver it says something like apcm? What the .... Both are 36 Mhz (Aussie), does anyone know if I can match them or maybe some troubleshoot ideas. Cheers.
RE: PCM 9X II compatibility
From memory, the 12DA is only for use with the PCM12X using APCM. The 9XII only supports Z & S type PCM and will not work with an A type PCM receiver.
Sorry
Sorry
