AR7600
I have several of the named receivers and I am trying to determine what type of modeling are they designed to be used in, aircraft, helicopters, etc?
Dwayne
Andy
Just a note to dispel any misunderstandings about range.....
A single reciever has just as much range as a reciever with a remote. What it lacks is path diversity to over come shadowing from components that may come into the RF path like ESC's, motor's or the like.
Actually, getting away from "shadowing" is only one advantage of multiple Rxers. Another advantage of a remote Rxer is to improve antenna polarization. If you have a Rxer horizontally polarized and the transmitter vertically polarized, you just lost 30 dB of your signal (e.g. Knife Edge flight with a Rxer antenna positioned vertical when upright.). A three (3dB) loss is 50% of your signal. So a 30 dB loss is very significant.
With a remote Rxer positioned cross-polarized to the other Rxer, you increase your overall Rxer's ability to maintain the same polarization as the transmitter, thus increasing your range. If you have three Rxers, you even further improve your odds of maintaining a similar polarized Txer to Rxer path. In the above Knife Edge flight example, can you imagine the signal loss if the tip of the cross-polarized Rxer antenna is pointing directly at the Txer?
Planes that fly "way out there" (e.g. Jets & Giants) typically have multiple remote Rxers. Planes that fly "in your face" do not typically need them. The remote Rxers give them that additional range. With three Rxers properly positioned, you can typically have at least one Rxer properly polarized with the Txer. If you have a lot of conductive material to deal with, 4 Rxers may be needed to maintain a properly polarized path that is not shadowed by something on the plane.
By the way; Only one Rxer is used at a time. When the Rxer Control Unit (my choice of words) switches to another Rxer, that is when it records a Fade on the Rxer that has just become weaker than the one it just selected, which has the stronger signal. We always used to call that "voting."
Andy
That's not how the remote receivers work, Len. It doesn't switch based on voting - all receivers are used all the time, each generating the same message. As long as any one delivers a message, it will be used. If any one does not deliver a message (nothing about strength) it will be recorded as a fade.
Andy
I knew I would finally get it out of you. I just have to keep trying.So we are not voting on RF signal strength.
Questions, ...
if a Rxer does not deliver a message but one other Rxer did provide a message this records a Fade on the Rxer that did NOT provide the message?
If a Rxer delivers a message but the checksum is wrong or the message is incomplete, it records a Frame Loss?
If none of the Rxers delivers a message, then a Hold is recorded? Or is the Hold RF based?
Why would the Spektrum want to process the same signals from each Rxer? Seems terribly inefficient, especially when you have 3 or 4 Remotes. If say, ... 3 remotes provide data, is there a precedence (e.g. use the first good frame and trash the rest as long as the frame used had the right checksum, etc.)? If you are not voting on RF signal strength, then it seems like the processor has to have some sort of precedence to sort out the redundant data. After all, how can it take all the data for all remotes simultaneously and why would the developers waste time decoding redundant data?
How can one answer create so many new questions, eh?
If a remote does not deliver a message, that's a single antenna fade. Note that if you remove a remote, you won't see fades reported and it will restart at 0 when you plug it back in because the remote was power-cycled.
A remote will not deliver a message if it got a bad check. That will also be a fade.
If no remote delivers a message for the same frame, that counts as a frame loss.
A Hold is when 43 consecutive frame losses occur.
Computers are horribly inefficient. We throw thousands of transistors at a problem that could often be solved with a few caps and resistors.
There doesn't need to be a precedence. The computer can receive data from all the remotes "simultaneously" and store it all in separate buffers, one buffer for each remote receiver. Then all it needs is to do is pick any buffer that was just updated and use the data (because all buffers have the exact same message content in them).
People coming from an analog world have a real problem comprehending the fact that signal strength has no correlation to delivered message quality in a digital world. Remember PCM? You either had perfect control or no control at all. With FM you could tell when you were glitching. In that regard all the modern 2.4gHz systems are more like PCM. Signal strength doesn't matter.
Andy
I suppose if I had time to surf around all the related forums, I would be a grounded pilot.But, I will look into the other forum.
