DX-7 Dual Aileron Programming
PA
I know it's something simple that I'm overlooking, I just can't figure it out. New airplane, dual aileron servos. DX-7 radio. Everything is hooked up exactly as the manual states. Right aileron goes to AIL port, left aileron goes to AUX port on receiver. Flaperons enabled. Like I said, I went by the book.
Problem is that the ailerons are reversed and nothing I do will change it. When Ii want the right aileron to go up, it's going down. I went into the servo reversing menu and tried every combination of reversing that I could come up with, and none of it made any difference. Same problem, ailerons reversed.
So I found the Spektrum manual on line and found the section pertaining to dual aileron/elevator servos. Lots of information, including step by step directions of how to program for this. Some stuff didn't make sense, but I followed their directions exactly, guess what, it got worse. The ailerons were now hooked together-both up, both down. Very frustrating. What's even more frustrating, is that this is not the first airplane I have on this radio with dual aileron servos. I've programmed dual ailerons before and it's worked, it just won't work this time.
Could there be an inherent problem with this particular model selection on my radio? Should I abandon this model selection completely and go to another one and try it all over again? I read about a "model reset" that you can do, but for the life of me, I can't find in the manual how to do this.
Has anyone encountered anything like this?
RE: DX-7 Dual Aileron Programming
ORIGINAL: cougar347
Could there be an inherent problem with this particular model selection on my radio? Should I abandon this model selection completely and go to another one and try it all over again? I read about a ''model reset'' that you can do, but for the life of me, I can't find in the manual how to do this.
PA
Yup, I sent it out to multiple forums, trying to get a solution. Thanks for your advice, but so far nothing has resolved my problem. Things still aren't working.
I'm going to ditch my DX-7 for this plane and revert back to my trusty old Futaba 9CAP. I will give the Spektrum tech guys a call tomorrow and see if they have a solution.
Appreciate the help.
ORIGINAL: cougar347
There is really no reason to give up on the DX7.
Did you reset the model before programming? I recently had a struggle with a corrupted model. Once I reset the model and re-programmed it, the problem went away. Also, in another situtation I had to use a wing type that was not the one that was obvious. I just changed wing type back to normal and all was well. Since, I now only use programmable servos. I now typically program the servos.
ORIGINAL: Len Todd
