Transmitter Beeping
MN
Transmitter Beeping
My friend has a DXS8 and with telemetery module hooked up he gets a beep and screen flash after 5 to 6 elevator up-pulls on the stick the transmitter beeps once and the screen does a momentary flash It keeps doing this on successive applications of the same kind. . The same thing happens on a 5-6 down-pushs on the stick. ONLY the Elevator does this, NO other control input. If he unplugs the telemetry module NO beeps! What's up?
Sincerely - Darryl
Sincerely - Darryl
What sensors are connected to the telemetry unit?
Are any alarms set in the TX?
I'm also wondering what kind of current the elevator servo(s) draw at full deflection.
It may be that the travel needs to be set so that the servos or the elevator doesn't hit the mechanical stops.
MN
Hi Flyinwalenda - I didn't call Horizon and even posting on the JR/Spectrum factory site didn't get a response from them. I do get better from Futaba even if they don't quite get it either. Just guess I'm not going to dish bad about anyone. Seems we modelers have to figure lots of things out for ourselves in resects of this great hobby of ours. Good thing the forums help on things. Sincerely - Darryl
You're better off using the "I have an issue" link on the Community site. You see that link when you have radios registered. (I assume you mean DX8, not DSX8).
Of course, the best way to get help is through this link: http://www.horizonhobby.com/content/...der-contact-us
Andy
