JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
DX8; dual flap servos-can they work together?
Old 10-03-2013, 07:03 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Default DX8; dual flap servos-can they work together?
I have two aileron servos and two flap servos. One of the flaps go up, the other goes down so I have to change one of them....is there a way to do that with the transmitter, or do I need to use a MatchBox?
The Transmitter set up has the two aileron and two flap servos displayed. I can adjust the left flap servo, but for some reason, the right servo will not respond to the transmitter's requests.
Suggestions?
Jerry
PS Thanks in advance - this is going into a Piper Warrior
Old 10-04-2013, 11:52 AM
AndyKunz
Are you using 1 servo port for them or 2 (ie, is your wing type 2 Ail/1 Flap or 2 Ail/2 Flap)?
If you use two receiver ports, then you just go to the Servo menu, select Reverse, select the flap that's backwards and reverse it.
Andy
Old 10-04-2013, 03:43 PM
tailskid
My Feedback: (34)
tailskid's Avatar
I'm using a "Y" connector and connecting to the aux 1 port on the rx. I am also using the two aileron, two flap setting on the tx.
Old 10-04-2013, 05:41 PM
AndyKunz
Take the Y out, plug the other flap into the specified channel on the receiver, and reverse the channel. If you are using a Y, then you don't tell the transmitter you have 2 flaps.
Andy
Old 10-04-2013, 11:10 PM
tailskid
My Feedback: (34)
tailskid's Avatar
I'll try that on Saturday...thanks again.
Old 10-05-2013, 05:44 AM
Captain John
Stay away from Y harness....they can cause trouble.
Old 10-05-2013, 08:55 AM
tailskid
My Feedback: (34)
tailskid's Avatar
Yep, just working with the flaps I've come across a 'new' "Y" connector that made one servo go crazy.....I'll go with two channels to resolve this issue.
