DX18 Servo setup for the Ch# > 10 without XPlus
Could I see the SERVO Setup ( Travel/S.TRIM/REVERSE) for the channel# >10 if I could use receiver with Xplus ?
It seems I could see these Servo Setup manual for CH#>10 in the case of AR9020 + XPlus Module , But I do have problem to see those menu if I use AR10000, AR12020 , and JR1212 .
Any solution ?
Any solution ?
Plug the servos into channels AUX6 and AUX7 (11 and 12).
Enable X-Plus.
Do the configuration using X+1 for AUX6 and X+2 for AUX7.
When you are finished, disable X-Plus. The channels will still use the settings you created for X+1 and X+2.
This is in the manual for DX18 and DX18QQ.
Andy
Enable X-Plus.
Andy
