JR 11x compatibility with Spektrum Receivers
Hello all,
Can someone help me out and tell me if the following Receivers are compatibile with the JR 11x. I think they are but need to confirm:
1. AR8000
2. If the AR8000 can be used will the TM1000 telemetry unit work with the JR 11x?
3. AR6115e
I looked in the JR 11x manual and it doesn't show these receivers but they both say they are DSM2 / DSMX so I think they should work okay.
Keith
1. AR8000
3. AR6115e
Keith
My Feedback: (41)
Hello all,
1. AR8000
3. AR6115e
Keith
1. AR8000
3. AR6115e
Keith
The TM1000 telemetry unit will not transmit to your tx, you'll need one of the dongles (which were on sale the other day so they may be going away) and use that with either an iPhone or iPad.
The AR6115E is not a Data compatible rx. The newer versions of the small rx's have a red light that will flash to convey the information but there is no port for the Flight Log and that is where the TM1000 plugs into the rx.
Thanks Zeeb - I thought I was correct but the JR manual didn't show them.
I figured as much on the Telemetry. Don't watch it while flying but is good to have for pre-flight.
Keith
Keith
