Help Programming Flaps on a DX8
My Feedback: (30)
I have a plane with 2 aileron servos and 2 flap servos. I have the flaps working, but only can get up and full flap. The middle position on the Aux 1 flap switch doesn't work. The manual isn't very clear. I have the flap feature working putting in down trim when the flaps are down. I'm missing something somewhere.
Can anyone help?
Can anyone help?
Hold down the CLEAR and BACK buttons as you power up the radio. Wait until you see the Raw Input screen.
Now toggle the switch to each position. Do you see it change between 0, 1, and 2? If you only see 0 and 2 then this is a hardware problem and you'll need to have the radio serviced.
If you see all three then it's a configuration problem. Please post the SPM file for it and I'll take a look.
Andy
Andy
