Satellite loses it's bind
My Feedback: (34)
the satellite binds first, then the Spectrum 7000 Rx gets a solid bind, everything works. Then 30 or so seconds later the satellite starts blinking......is it safe to fly? All servos work as desired -on the bench....... I'm talking 30cc sized airplane.
Digging a little deeper, the AR7000 receiver is DSM2 only I believe, is the satellite the one that came with this receiver? The orange blinking light on the Sat might indicate it lost power momentarily and the flashing is the brownout indication, perhaps a loose wire between sat and main rx?
The rate won't change - it's telling you it lost power momentarily.
I would replace the cable between them. And when you put it back, strain-relief it an inch or two away from each end so that the wire isn't getting worn out by vibration.
Andy
Andy
