Swapping Models Between TwoTransmitters
I copied a model from a DX-9 to a DX-18. I tested the model on the DX-18 and everything worked just fine. Then, I tested the preset failsafe using the DX-18. One half of the elevator dropped fully down. I programmed the preset failsafe using the DX-18. Then I again tested the preset failsafe. Both elevators stayed right where I had them when I programmed the preset failsafe. Moral to the story: When swapping models between compatible transmitters, do not forget to check the preset failsafe!
