View Poll Results: Which XG (6,8,11,14,)do you fly and what are your pros and cons?
Multiple Choice Poll. Voters: 31. You may not vote on this poll
Which JR XG?
I have both the XG11 and XG8. Absolutely love the XG11. The XG8 is very new to me, but I'm looking forward to getting it set up and doing some testing with it this year. The DMSS and telemetry features are fantastic. Until last year I was flying the 9503. Made the switch over during 2014 and absolutely love my new radios!
XG-8
Pros
The LiFe power source and built in charger are great
The ergonomic feel is good
I like the illumination light displaying the state of charging, readiness, range check, or servos off
I like the quick binding
I like the additional trim switches for trimming elevators for loop tracking and ailerons up and down for subtle changes to pitch to dial the elevators neutral
I love the slide switches
Cons
I found the manual tough to understand at times . it seemed to expect that I was upgrading from a very recent technology - there are things that I still don't understand
I don't like that the RF board is held onto the mother board only by the header pins - it came off once- fortunately when I was not airborne
I don't like that the altimeter telemetry volume can't be adjusted loud enough to be heard
I don't like that JR America didn't fix the above in a software update - seemingly ignoring my request
I don't like that the computer logic glitched on it, causing the elevators to go full over in opposite directions causing a crash
I dislike the protocol for selecting a model
Pros
Cons
XG8
I've had mine 3 years now...
The Pro's are stating the obvious so ill just write down my cons experience
The radio has a every 1min alert for timers, I just need this on the final minute... and worst is it can not be disabled...
I also owned a DX8 and I quite liked scrolling down on the menus rather than scrolling sideways like with JR systems...
XG series is still based on the old school type menu from 6 and more years ago which you still find in the old DSX radios...
Also a larger Life battery would be nice, as the 1400mah standard one doesn't last as long as one would like it to...
Also I quite like the solid triangle antenna which spektrum has on DX9 and later models, this looks rugged and strong...
I am planning to get the XG14 but simply because of more channels which I don't need but I can have it so why not
My Feedback: (8)
I 'voted' for the XG11 because I thought it was a recommendation, not what we are flying. I have the XG14 with no real complaints, but after coming to better understand the manual, differences, and feel of the radios I'd probably prefer the XG11. The XG14 'fits like a glove' but the XG11 is also molded to fit well in the hands; it also has the 'metal' case. It has some higher end functionality that I would appreciate (same basic functioning with a little more control). But I am happy with the XG14 although it is still relatively new to me.
My Feedback: (61)
I am new to JR after 20 years using Futuba products. I choose the XG 8 because it allows me some room to grow. I have found the manual very hard to follow. I have read the manual about three times and still have trouble following the sequence. In the model set-up menu you are given the option to choose between heli, airplane and glider.
When you make your selection your next screen is posing a question RF on or off? The scroll wheel does not allow you to choose between either. The only key which allows you to navigate from this page is the control key which sends you back to the My list page. I NEED SOME HELP.
Love the looks and feel and surely hope the quality of JR is still their. My arrival to JR came in a round-about way.
Prior to my JR I had ordered a Graupner mx 18. I had read all the reviews and found them favorable. I received the radio system and really liked the looks and feel especially the color LCD screen. I began the binding process only to find a serious quality control issue. The S-2 switch had zero spring tension and would allow random throttle control thus the prop began to turn unexpectedly on my Parkzone. After discovering this problem I immediately re-packaged the equipment and sent it back for a full refund. I understand it could have been and isolated case, however, I was not willing to take the risk.
The RF deck is not just held in place by the header pins. There should be an adhesive pad between the 2 pcb's. Has yours been away for repair or something ??
No...mine has not been back for repair and there was no adhesive pad. There is however now a piece of foam glued to the back of the case which prevents the RF board from coming off the header pins.
After struggling with the set up I got on-line and sent JR Americas tech support an e-mail. To my amazement I had a JR technician call me and walk me through the process of setting up a model. We discovered in the process that my model had a bad aileron servo. This is the type of support that will keep JR on top. I'm 100% confident that my choice of JR was the RIGHT choice. JR Rocks!
My Feedback: (76)
I voted for my xg11. I've never had a problem with it. Horizon hobby's service has always been outstanding. So...........I bought my new JR 28X from Horizon. I trust JR's service will live up to the standard set by Horizon. Since the 28X is DMSS maybe we should add it to the poll.
I got the XG6 as an introduction to DMSS. I didn't expect too much from It ( I picked it up for $89 ), but it has really grown on me the more I fly with it. Its very easy to add a LiFe battery for TX power. The design is really comfortable -- I assume the higher end designs will only be better, The programming logic is fairly easy to use, but I have used JR computer radios for over 25 years. Obviously, the next question is do I go to the 8 or 11 for my next one. The XG6 is a great place to start, so I bought one for my son as his first radio. Lets hope JR America's keeps JR service level on top.
My Feedback: (61)
Here you go. Just unplug the dry cell unit and plug in a JR type. Real easy. I don't charge in the unit, as I have several ready to go and just change as needed. I use the same battery pack for RX and TX on the small planes I am flying with this radio. I am just trying 2.4 and haven't trusted any of my nice planes to it yet. Very nice feature for my use.
My Feedback: (61)
My Feedback: (43)
I have had the XG14 for about a year now. While I love the gimbals, I am not overly thrilled with the look and feel of the radio itself. To me, the XG14 is cheap looking by what I consider to be JR standards. I bought mine without ever seeing or holding one and found out afterwards that the 14 is a small transmitter. I think it was developed with the DLG guys in mind since the normal spot of a retract switch is occupied by momentary switch which JR offered to swap to a two position for free. My hands are just too big and it makes the transmitter feel like a toy.I think the technology is first rate, the programming is good, although I am still learning it, and the service thus far has been great. I would get the XG11MV if I could do over again.
I own an XG11 after having the silver Zero model, its a really solid radio, good layout of switches and logical programming. Battery lasts the day for me and set-ups have been straight forward as is the updating proceedure. On the basis of that I bought the XG6 which is perhaps the 'price point' model of the range. Its light, again easy to program with just a few differences to the XG11 and after upgrading the dry-cells to a li-fe lasts all day. Its perfect for park-flyers, sport flying, HLG etc etc.. Not a bad choice for beginners either as my 9 year old son has no issues with it and he's finding his way in fixed-wing at the moment. Less switches on it (2 position only)and the two buttons on the front panel are a bit limiting. I think compared to the Spektrum range there is a price premium on JR products but I'm guessing the little touches of quality do add up and JR are a much smaller outfit than Spektrum so costs are a little higher.
