dx 18 throttle curve
Yes, sure! You just use a switch which defines the situation, and assign that switch to the Throttle Curve. If you're using a DX18QQ or DX18G2 then you can use a combination of two switches to define if the mix is active or not (select Combo for the switch name; it's at the end of the list).
Andy
Andy
