AR7010 DSMX and TM1000 compatibility
Location: Santo DomingoMake Selection, DOMINICAN REPUBLIC
Hi,
I have a DX8 with AR7010 DSMX receiver on a 20cc Big Stik airplane. Need to know if I can add TM1000 telemetry module to this combo.
Cheers,
Francis
Cheers,
Francis
Thanks Aerocal for your answer.
I plugged AR7010/TM1000/DX8 and got orange led blinking. Then performed binding and got nothing. No movement on servos neither telemetry on the screen.
Please help.
Francis
Please help.
Francis
CA
Ok. You have an AR7010 and TM 1000. Is there a remote Rx installed with the 7010?
You should have fastblink(bindmode) on all 3 units before initiating Bind with Tx.
The preferred way to get all Rxs in Bindmode is to put a Y in the telemetry lead and a Bindplug in the extra lead from the Y. I try to avoid using the button on the TM for Bind.
If you cant get a solid orange led on all 3 units try moving a bit farther away when you Bind.
If you have solid orange led on all 3 and still no servo movement make sure the servo leads arent plugged in upside down.
