Servos started driving when JR922 turn on. Went thru re-bind, now its worse
My Feedback: (24)
Hoping someone can help me.
Yellow P-38, JR 9303 radio with a 922 power safe with 4 satellites.
Before Sunday I had NO problems at all. You could power up RX, with TX on or off and nothing would happen until it was connected to TX. It would then work as it should.
Sunday, there were a couple servos that drove when I plugged batteries in, one of which was the retracts. Now that I gone thru the rebind process per the manual a dozen plus times, several servos, but not all drive until the RX connects to the TX. They drive one way, the same way each time I bind, and once RX connects to TX, they center and work fine
I have tried the smart safe, and preset failsafe binding procedure with no luck...any ideas??
Any help would much appreciated!!
