JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
AR9350 RX Configuration Questions
Old 12-07-2015, 07:36 PM
Robert Willis
Default AR9350 RX Configuration Questions
The PC application utilized to configure the AR9350 does not include the capability to adjust the Dual Rates and Exponential settings similar to the iOS application. I have being seeing forum discussion that indicate that the Dual Rates and Exponential should be adjusted in the RX which contradicts the information on the Spektrum website.
Questions:
1. What is the correct procedure to use to adjust Dual Rates and Exponential (RX or Configuration Software)?
2. If the answer is configuration software, when will the PC based software be updated to allow this?
Old 12-08-2015, 02:24 PM
AndyKunz
As noted from the discussions regarding the App versions for the AR636 et al, the rates and expo have been removed from them and you should be using the settings in your transmitter now. Yes, the documentation lags.
Andy
Old 12-08-2015, 03:17 PM
Robert Willis
Thanks but the latest iOS application still has the Dual Rates and Exponential for the AR9350.
Old 12-08-2015, 03:30 PM
AndyKunz
Yes, the one which hasn't been updated yet to remove them.
Andy
