Need step by step procedure to adjust sullivan smoke rate with throttle control
I just set up a Sullivan smoke sys in cap 232. Just running on off switch but flow is too high Lots of wasted smoke fluid . What is the procedure to run Sullivan using throttle control . What do I set up in transmitter to allow throttle control to control smoke flow in conjunction with engine rpms. Thanks
CA
I guess it would depend on what you are using for a Tx.
Generally you want your smoke pump on its own channel. You then set the correct endpoint for Off on the Aux channel and then use a Thr>Aux Mix to vary your smoke rate.
