New Dx6 question
New Dx6 question
I recently purchased this radio and I am very happy with it.
Does this radio have built in telemetry for receiver voltage or do I need to purchase
a telemetry unit?
I have a couple of friends with the Hitec 9and 9x and this feature is built into the radio
and optima receiver.
a telemetry unit?
CA
Yes you need a TM with that Rx. IMO a worthwhile investment. It not only will tell you the charge state of your battery but will warn you of a problem in wiring,switch or even a servo going bad. Anything that may cause the voltage to drop at the Rx bus where its needed to prevent a brownout/reboot.
It also comes with a temp sensor. Once you figure out how to mount it on your engine you will find you can safely run a little leaner while monitoring temp with an alarm without worrying about it getting smoking hot inflight with no warning.
