JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR DSM Air Module 9 channel
Reply
Old 03-13-2016, 01:25 AM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR DSM Air Module 9 channel
Installed this unit in a JR 10X transmitter and ops checked it using a Spektrum AR7000 receiver. I cycled the transmitter/receiver about ten times and I lost bind twice. The LED light on the receiver was a solid orange which indicated a solid bind took place. The servos are getting voltage but no signal. The receiver worked fine when using a Specktrum DXi6 transmitter. Could I have purchased a defective module?
flycatch is offline
Old 03-13-2016, 04:04 AM
yorkiepap
My Feedback: (18)
yorkiepap's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also use the DM-9 modules on my 10X's & so far, not any issues. Did you try a couple other Rx's? Your issue could provide a more solid indication that the module may be defective if this is happening with other Rx's. Is your 10X set to PPM? Are any of the switches not in their fully rearward/upward position? Being electronic, anything is possible. I've been using my modules for 4yrs without issues & I purchased them used on RCG, so I find them to be very reliable. Send it to HH/Spektrum & let them test/repair/replace it.
Denny
yorkiepap is offline
Old 03-13-2016, 09:22 AM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply. I only have one 2.4ghz receiver but I'm awaiting an AR9000. I contacted the vendor and Horizon and awaiting replies. Like I said the receiver worked fine with the DXi6 and I'm leaning toward a defective air module.
flycatch is offline
Old 03-14-2016, 07:46 AM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a bad cable between the AR7000 and its remote receiver? That'll do that...
Andy
AndyKunz is offline
Old 03-22-2016, 08:12 AM
grizzly59
grizzly59's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have mentioned before on these threads that I had an 8103 and a 10X using that module.I used it often on a 10x for 4-5 years. I could bind to DMS2 receivers but never could bind to DSMX receivers when they came out. Nobody at Horizon could give me the reason why and stated they were backward compatible. They did send me a new module but I bought a 11X transmitter and did not mess with the module. I tried them with receivers with remotes and the smaller ones without.
I asked about this issue several times on the internet and stated they tell me if their's works with a DSMX receiver. Got one reply after asking the question twice in a year period. He said his works?????Why not more replies as many modules are out there. Just sharing my experience.
grizzly59 is offline
Old 03-22-2016, 08:19 AM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The modules do not work with certain receivers, such as the Apprentice SAFE. Most receivers, both DSM2 and DSMX, will work fine with a module, but there are a few holdouts.
If you need to know about a specific module/receiver combination, I suggest you talk to Product Service (NOT Support) about it.
Andy
AndyKunz is offline
Old 03-22-2016, 10:48 AM
flycatch
My Feedback: (26)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After further research I discovered that you most be separated from the receiver by 2 meters during the bind process. This is a standard rule but does vary between different receivers. In the early days of FM single conversion receivers we used the word "swapping" to describe the condition. If you were too close to the receiver with the FM transmitter radiating power, it would overdrive the capability of the unit,, to decoder the modulation signal. This same problem is in play with the 2.4ghz technology. The 2.4ghz receiver will bind but not lock onto the binary code of the transmitter module.
flycatch is offline
Old 03-22-2016, 10:52 AM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, swamping is very definitely a problem if you're too close.
Andy
AndyKunz is offline
Old 03-22-2016, 06:19 PM
yorkiepap
My Feedback: (18)
yorkiepap's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmmm...talk about Karma? I post that I've not had any issues & yesterday, while installing my "Primary" DM-9 to bind a new plane, both locking tabs broke(I hate plastic!). This morning I got on HH's website & entered a Service Request. Got it shipped out by 2pm. Glad I have a "Secondary" spare module.
Denny
Old 03-22-2016, 06:20 PM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you get just the plastics, or the whole thing?
Andy
AndyKunz is offline
Old 03-23-2016, 06:45 AM
yorkiepap
My Feedback: (18)
yorkiepap's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Andy
Andy,
If your response was to my post, I sent the complete module to HH since I felt while it was there, it would be tested o/a. Thanks...
Denny
Old 03-31-2016, 07:01 AM
yorkiepap
My Feedback: (18)
yorkiepap's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
KUDOS!!! to HH/Spektrum. I just got my DM-9 module back from HH fixed, tested & NO CHARGE!!!! THAT is what I call service. Thank you.
Denny
