New Spektrum DX7 & Hobby King R615X receiver
The Hobby King R615X receiver may not bind correctly with the new Spektrum DX7. After binding is complete the yellow light flashes slowly and sometimes the Red light flashes. The factory setting on the DX7 is set for DSMX and needs to be changed to DSM2. My qualifications don’t allow me to speculate why the conflict between the HK R615X receiver and the new Spektrum DX7 exists however the program changes work for me.
Procedure: Turn on transmitter power, Press roller and go to Function List scroll down to System Setup press roller bar, Caution screen roll over Yes (the aircraft must not be in operation) and press roller bar, roll down to Frame Rate press roller wheel, scroll down to Mode press roller wheel until DSM2 appears roll wheel up to List press roller wheel, roll back up to Main Screen press roller bar you are ready to Bind. Bind your aircraft when binding is complete in the upper left corner of your screen you will see DSM2. It has been reported that this also works with the Spektrum DX8.
