JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
How to bind DX9 and DXe wirelessly?
Reply
Old 09-16-2016, 06:52 PM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to bind DX9 and DXe wirelessly?
Iím trying to use my DX9 as a wireless Programmable Link Master trainer along with my DXe as a Programmable Link Slave.
I used the Spektrum (USB) Programmer to set the DXe to the Programmable Link Slave and saved the setting.
I disconnected the programming cable and powered the DXe off.
I then put the DX9 in Trainer mode as a Programmable Link Master.
I then clicked on BIND and saw the Binding message.
I powered on the receiver in the airplane and then powered on the DXe.
I never could bind the two.
What am I doing wrong?
Jack
Jack_K is offline
Old 09-17-2016, 04:40 AM
DP01
DP01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Perhaps you're not powering on the DXe in the "Bind Mode". Per Item 6, Page 20 of the DX9 Manual which reads: "6. Enter bind mode on the slave transmitter following the
instructions provided with that transmitter.".
Dennis
DP01 is offline
Old 09-17-2016, 06:09 AM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dennis
There are no instructions in the one-sheet "manual" for the DXe. I put it in bind mode with the USB interface to my PC.
Jack_K is offline
Old 09-17-2016, 07:02 AM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a little more detail.
I used the Spektrum (USB) Programmer to set the DXe to the Pilot Link Slave and saved the setting.
I then put the DX9 in Trainer mode as a Pilot Link Master.
I powered on the DXe while holding the BIND button down.
The LEDs on the DXe started blinking. I assume that means it's in Bind Mode.
Nothing else happened.
Then I tried this:
I put the DX9 in Trainer mode as a Pilot Link Master.
I put a binding plug in the receiver in the aircraft.
I powered on the aircraft. The receiver started blinking. OK so far.
I then clicked on BIND on the DX9 and saw the Binding message.
I powered on the DXe while holding its BIND button down.
The LEDs on the DXe started blinking. Again I assume that means it's in Bind Mode.
I waited and waited and waited, but the DX9 never would bind to the DXe.
I put the DX9 back to the main screen.
Now the aircraft was bound (?) to the DXe, but the DX9 no longer had any control of the plane.
I never could bind the two transmitters.
Jack_K is offline
Old 09-17-2016, 07:39 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The receiver in the model must be bound to the master, in this case the DX9, not the slave DXe. When doing the bind procedure for wireless training I assume that the receiver must not be in bind mode, or even powered up. This is just a swag at your problem. I don't have any first hand experience with wireless trainer setup, but the receiver being bound to master radio is a must.
Pete
pilotpete2 is offline
Old 09-17-2016, 10:31 AM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pete
The receiver WAS bound to the DX9 before I started the sequence.
Jack_K is offline
Old 09-17-2016, 11:04 AM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It works fine in the wired trainer mode, but still won't connect wirelessly.
Jack_K is offline
Old 09-17-2016, 03:56 PM
DP01
DP01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Desperation guess! Try binding with the transmitters several feet apart…
DP01 is offline
Old 09-17-2016, 06:06 PM
Jack_K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just found out the DXe is supposed to have a "wireless bind" button, but mine does not.
Jack_K is offline
