JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
XG 11 low voltage
Reply
Old 09-19-2016, 04:59 AM
pippy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default XG 11 low voltage
Hi all, what is the lowest voltage I should let the transmitter operate at? Is 6.3 volts ok? Also is there a low voltage warning whereby you could then safely land a plane?
pippy is offline
Old 09-19-2016, 10:57 AM
AWorrest
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My XG 11MV uses a three-cell pack rather than a two-cell. The default setting on it is 9.0V. When the transmitter was new, I ran a discharge curve on the battery as the poly pack LiFe configuration was new to me. Based on the curve, I bumped the alarm up to 9.5V. The transmitter is now two years old and the alarm point had to be lowered to the default 9.0 as the overall battery voltage has declined with age.
There is nothing wrong with increasing the alarm point when the battery is new. In time you will probably use the default setting. The low voltage setting is indicated by the vertical line on the INFO page TX voltage graph. There is an audio alarm when the voltage drops below the setting. The only way to turn it off is to reset the alarm point and turn the transmitter off.
Allan
AWorrest is offline
Old 09-20-2016, 01:53 AM
pippy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Allen for that information. I will have a look at that.
pippy is offline
Old 09-21-2016, 03:37 AM
SAB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Paul,
I have an XG11 & originally left the default alarm at 6.0V - However, when flying indoor last year I got around 5 mins of Tx operation once alarm sounded at 6.0 V - I looked at several generic LiFe discharge curves & for 2 cells 6.0V is clearly too low, the "knee' of the curve is around 6.2V so I set my alarm to 6.3V to give me a little bit more time to land in the knowledge I will still be OK.
Steve
SAB is offline
Old 09-21-2016, 04:20 AM
pippy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Steve, that is reassuring.
pippy is offline
