Telementry sound problem
My Feedback: (7)
Have telementry setup for air speed at this time. I was looking to get 5 sec. up dates & it does, to help my landing speed.
So I assigned sound to a switch ( H ) with two positions silent and air speed. When I put the switch in silent mode
it keeps on announcing the speed. Ist it suppose to shut off in silent mode . Rich B. appreciate so help ????
My Feedback: (7)
Whats SPM, ? Found help , horizon hobbies, they say no solution . The radio keep playing the speed status according to the time you set 5 sec 10 sec etc.. You cannot designate a sw. to shut it off or on. Sounds ridiculus So to have speed update by sound
you have to listen to it every 5 , 10 15 sec or what ever you set. I was looking for it to aid in landing speed only not the whole flight,
If you leave the sound off it reads on your display, guess you spotter has to look and tell you your speed. not so good?
Any body have a way around this? Rich B.
The SPM file is what you get when you export. How to export is in the manual.
Yes, you can get reports switched on and off, but it takes some work. Over on RCG we have threads specifically on how-to for stuff like this.
If you export the SPM file and post it here, I'll use it as the example for how to make the changes yourself.
Andy
(The guy who wrote most of the radio code)
Andy
My Feedback: (7)
Andy, appreaciate the help will get the info for you. rich b .[ATTACH]2187646[/IMG]
GOT THE FILE. HOPE YOU CAN MAKE GO OF IT. THANKS RICH B.
Andy I think I met you , did you run boats out east NJ or NY area in NAMBA.
15 20 years ago. My full name is Richard barile. ran mostly out riggers.
I was able to open it on AOL only, if you have a problem with it . I printed ( 25 pages) it could be half of that , don't know how to down size. If you tell me what to look for I'll scan that page.
Last edited by SACKRC; 10-27-2016 at 06:04 AM. Reason: SD FILE BVM JET /AOL READ OUT
