2 throttle curves - Spektrum DX9 - using switch ??? possible?
I want to use a 6S battery and limit my full throttle to 80% (using the throttle curve) for most of a flight, then, click a switch and change the throttle curve to 100% at some point during the flight. It seems like I could do this looking at the throttle curve settings - set the switch for any switch, then change the throttle curve from 80% at the high end, to 100% at the high end - but I can't get it to work. Is this possible?
Scott
Scott
Got it. You need to connect a servo to see this actually work. Set Curve 0 for the throttle curve you want, then set Curve 2 and make sure the selected switch shows active, then Curve 3 and so on. With a servo on the throttle channel you can see how it works. IT DOES NOT SHOW ON THE CURVE GRAPH WHEN YOU CHANGE THE SWITCH.
