JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
AR636 Iphone programming issues
Reply
Old 03-21-2017, 04:58 AM
g4uvz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AR636 Iphone programming issues
Ok Having sorted out the binding issue I am trying to program the 636 with the Iphone
I can program a 'standard model' Crescendo1 as an example..this all works well. However there are unexplained dual rate settings which change when I go from FM1 2 and 3 ..The DRs are all set to the same on the screen however in FM1 there is limited down elevator but I have no idea where this setting is being applied. If I download a warbird then the gyro gains only operate on one FM even though they appear in all 3 FMs Any ideas / help would be much appreciated !
g4uvz is offline
Old 03-21-2017, 10:05 AM
AndyKunz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you are using the AS3X Telemetry mode, you can see the applied rate at any time. What does that show you?
Andy
AndyKunz is offline
Old 03-21-2017, 10:39 AM
g4uvz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rate window mirrors the AP gains
With wishing to burden you further I have looked again at the Spektrum Youtube tutorials and have set up on FM 1 roll gain only ...pit & yaw at zero
FM 2 Pit gain and Roll & Yaw zero and FM 3 Yaw gain with zero on roll and pitch. And Good news it works as expected...however in flight mode one there is no output on ailerons and elevator from the tx! rudder is fine I have attached some pics which might help.
Really appreciate your help I don't like to give up but a s soon as I solve one problem another appears!
Adrian
ID:	2206413   Click image for larger version
ID:	2206414   Click image for larger version
ID:	2206415   Click image for larger version
ID:	2206416   Click image for larger version
ID:	2206417   Click image for larger version
g4uvz is offline
Old 03-21-2017, 10:52 AM
g4uvz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Adrian
g4uvz is offline
