JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Can you "lock" a switch?
Reply
Old 04-01-2017, 04:58 PM
krokodyl
krokodyl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can you "lock" a switch?
Hello. I have a dx7s, and am setting up differential thrust for my electric airplane. Everything works great, but when I flip to gear switch, one motor goes to 75-100% (can't tell wether it's WOT or not), and the other behaves normally. It's not too bad, but I want to avoid accidentally hitting this switch in the air. I tried inhibiting the switch, but this stopped the differential thrust from working. So, my question is: can you "lock" the switch to one position, so that you can still mix through it, but so that it does nothing when flipped? I can share how I did my mixes if necessary.
Thanks, Hubert.
krokodyl is offline
Old 04-01-2017, 06:12 PM
AWorrest
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You’ll have to specify what transmitter you are using before anyone can offer advice. If you are using the JR 9303, 9503, 11X, 12X or XG series. I would say you have mis-programmed the transmitter by not inhibiting the gear channel before doing the mixing.
Allan
AWorrest is offline
Old 04-02-2017, 06:03 AM
krokodyl
krokodyl's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using the spectrum DX7s and AR610 receiver.
Hubert
krokodyl is offline
