JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Spektrum Telemetry System for Mystique 2.9 ARF
Reply
Old 04-09-2017, 10:00 AM
Pisti
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Spektrum Telemetry System for Mystique 2.9 ARF
Hi,
I would like to build a system for Mystique 2.9 electric glider, that includes DX6 (Spm6750), a suitable receiver, and a telemetry system with vario and GPS (with voice).
I planned a Spektrum system, but I am not sure:
AR610 6-Channel DSMX Coated Air Receiver (SPMAR610)
TM1000 DSMX Full-Range Aircraft Telemetry Module (SPM9548)
Aircraft Telemetry Variometer Sensor (SPMA9589)
Aircraft Telemetry GPS Sensor (SPMA9587)
Will these devices work together?
If yes, how should I connect them? (because TM1000 has only 1 x-bus connector, and I would like to use vario and GPS as well.)
Thanks in advance,
Pisti
Pisti is offline
Old 04-09-2017, 12:19 PM
flyinwalenda
flyinwalenda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I would use the 6270T receiver as it is designed for carbon-fiber and fiberglass fuses and it has telemetry ports built-in.
To add multiple sensors to the X-buss port of the receiver you would daisy-chain the sensors using the two X-buss ports on each sensor (X-buss1,X-buss2). X-buss port of the receiver to the x-buss1 port of the first sensor and then the X-buss2 port of the first sensor to the X-buss1 port of the second sensor.
flyinwalenda is offline
Old 04-09-2017, 09:07 PM
Pisti
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you very much Brian.
Pisti is offline
