binding dual receivers in airplane...
My Feedback: (14)
AL
I have an airplane that I just purchased from a friend and the airplane has two spectrum receivers.. How do I bind both receivers at the same time and is that necessary... the receivers have a connection between them as they can work on one battery or two as needed...(should one battery fail) each has a switch... everything worked well with the sellers old transmitter but I have a DX 7 that I want to put this airplane on... Can I bind just one of the receivers with a binding connection and the other receiver will then bind at the same time...? Thanks..
