Spektrum Satellite JST Connectors
CO
Does anyone know the exact nomenclature for the small JST connector on the Spektrum satellite receivers? I'm getting quite a collection of failed satellite cables and want to fix them, I have a source, but I'm not quite sure which connectors they are exactly.
When I get a new remote receiver or telemetry cable, before it gets used for anything I apply either Tool Dip or Liquid Electrical Tape to the plug/wire area to provide a strain relief and to seal it somewhat from moisture (leads to oxidation/corrosion).
When mounting them in my models, they are mounted to the model frame. I leave only an inch or so at the end for plugging it into the device. This prevents vibration and violent maneuvers from stressing the wires or connections, promoting long life of the model
Andy
CO
The remote receivers and telemetry X-Bus connectors are JST ZH-series parts.
Andy
Andy
I have heard claims that some receivers will do a total lockout if a satellite drops off during flight, but what I have seen is the next time you power up the model there is no control at all until the satellite problem is resolved.
