DX7 with 2 ESC's for zero turn
I'm trying to build a zero turn project. I want to connect 2 speed controllers to work as a zero turn. One motor and controller on each rear wheel with a caster as a 3rd front wheel.
Can anyone help me with programming the DX7?
The transmitter programing should be simple and straight forward. For a mode 2 stick configuration, pick the Delta wing type and connect the right wheel to the right elevon and the left wheel to the left elevon. The tricky part is the speed controllers. The ones used for aircraft don’t cause the motor to rotate in one direction when the pulse is greater than 1.5ms and rotate in the opposite direction when the pulse is less than 1.5ms. Perhaps such ones are made for surface vehicles.
Allan
Allan
