Model Transfer to DX20
I get an error 11: 'Unsupported' invalid enumeration when I try to transfer an aero file via SD card from a
spektrum iX12 to a dx20.
Does anyone know whats wrong
You have to save the model data from the iX12 in the .SPM format not the iSPM format to copy to the DX20.
I have upgraded the radio to 2.0 (the latestsoftware )
Of the 14 models I downloaded to the SD card 12 worked perfectly.
The 2 that don't are of the same model Eurofighter Turbine
I just get the error 11: 'Unsupported' invalid enumeration and nothing else.
Thanks Andy her are two copies of the Eurofighter data sent from the iX12 and saved in SPM format
The second SPM file is all the other files that transfered at the same time without any problems
Steve
Steve
That helped immensely! There is an error in the iX12 export mechanism. I'll report it to the iX12 team for correction.
Thank you!
Do you need me to adjust the file so you can import it? Or are you OK with doing the programming yourself?
Andy
Thank you!
Andy
Hi Andy, Thanks for you prompt attention to my problem.
I would love you to adjust the file so I can import it.
You should find that both Eurofighter files are nearly identical.
I have attached both the iSPM files for you.
Thanks again
Steve
Thanks again
Steve
I'm on my phone right now so I can't edit, but I can tell you how.
Open it with Notepad++ or gedit. Line 11 says something like tailtype= unsupported. Delete the line completely.
The next line is subTypeB= 9
Change the 9 to 0
Save the file, and it should import just fine.
Andy
Change the 9 to 0
Andy
