JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
HELP Manual JR RG812BX Receiver
Reply
Old 11-21-2018, 05:33 PM
petya
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HELP Manual JR RG812BX Receiver
Dear friends, I am one of those longing for JR.
I have an XG14 still in use, and I need to bind an RG812BX receiver to work in Xbus mode.
I've done this once, but I do not remember the procedure. I know it has some trick, since the receiver uses the "easy bind" Name:  confused.gif
Size:  1.1 KB system, without the plug and two ways, one for PWM output and one for X-Bus.
I also remember that there is a differentiation in the lights in the receiver to inform if it is or not in X-Bus
Unfortunately I have not found on the net, nor on the JR Americas site, only the RG812B does not have the X-Bus feature.
If some good soul has and can do the charity of posting a good resolution photo of the manual, it already solves my problem.
Thank you very much in advance .
Best Regards
Eduardo
petya is offline
Old 11-22-2018, 03:28 AM
petya
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Deeforce guys who bought JR Propo's production rights got back to me very quickly (less than 1h) and they sent me the manual !!
My thanks go to the excellent support received from them.
https://www.deeforce.net/about-us-1
I'll leave a copy on this topic, if someone else needs ....
File Type: pdf
petya is offline
Old 11-22-2018, 11:56 AM
AWorrest
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is the same instruction sheet that came with my RG812BX made by DeeForce but labeled as JR. The caption, “AUX3/XBus Terminal –*This is set to AUX3 when delivered”, for the illustration in the upper right corner (under the topic Switching Aux3 between PWM and XBus) erroneously points to the BATT/SENS connector. The AUX3/XBus connector is on the bottom left. The illustration is correct in pointing to the bottom right connector (BATT/SENS) as to where to connect in the SWITCH PLUG.
Allan
AWorrest is offline
