P-MIX
RE: P-MIX
Go to code 51 for instance or any other open program mix, press 4 and say 7 to use channel aux 2. You can select the channel of your choice. Then press enter. Press the page key twice. Then press SEL under where it says TRIM until it says TRIM ON. Then press the page key one time. Move the rudder stick to the left, and press the + key on the bottom of the screen until you get to 100%. Now move the rudder stick right, and press the + key again until it says 100%. Now exit the mix, and go to code 17 which Function select, and inhibit the channel that you are using for the second rudder servo. Then adjust sub trims, travel adjust, and servo reversing as necessary to set it up.
RE: P-MIX
If you want a multi-point mix, go to mix 6, 7, or 8 (code 56-58) and after selecting the channels you want to mix, it will ask for the TYPE of mix you want, press SEL under TYPE until it says CURVE. Then press enter.
