CCPM MIXING VALUE SETUP?
Hello,
I use JR X3810 now. I fly Sceadu CCPM heli, it's 120/3 servos CCPM system.
On function Mode: Swashplate Mixing, there is Aileron, Elevator, and Pitch Mixing Value.
The default value is all 60%, and for my Sceadu I must set pitch value at -60% so the pitch direction working
correctly.
The question is, what is the mixing value corelated with: swashplate control, ATV servo and everything.
I need everything info about it, because the radio manual explain nothing about it.
Please also give me advice and suggestion how to set them up correctly. And why?
Thank you in advance.
Albertus Herinanto
correctly.
Albertus Herinanto
RE: CCPM MIXING VALUE SETUP?
That is correct, the mixing value corelates with the swashplate control and the travel of each of those functions. The higher the value for say the pitch, the further the servos will move for the pitch function, and the same for the other functions of aileron and elevator. Going from + to - reverses that function. The percentages needed depend on the servos, the length of the arms on the servos, and the helicopter set up. Generally the helicopter manual will give advise on the length of arms needed, and give the percentage needed for that model with those arms.
