10X to 8103
My Feedback: (10)
CA
10X to 8103
Danny,
I know one can't transfer data between a 10X transmitter and 8103 (or vise versa), but can you manually enter all the parameters, such as servo travel, dual rates, expo, mixes, etc using the same numbers (assuming the mixes are available on the 8103) and get the same results in order to use both transmitter for the same plane as in a trainer mode? As usual, thanks very much for your help.
Russ
Russ
RE: 10X to 8103
You will need to reduce any sub trim values by half, the rest should be very close. It may not be exact, but may only require slight adjustments. With the pilot link function of the 10X though, you do not need to worry about setting up the slave 8103 TX for the aircraft, as the master will have control of the trims, etc.
