Ultra Stick 60 & JR 8103
My Feedback: (14)
CA
I feel kinda stupid but oh well.. I have a New ultra Stick 60 with a JR 8103. I am having all kinds of problems programming the radio. I think I have muddled my way through the programming so I can get full flaps at the middle position and crow at the full down position on the flaps switch. The problem that I am having is the the right and left aileron servos do not travel the same. one of the servos (the left aileron I believe) only gets 75% travel. I know this by looking at the monit option on the radio. I am not sure if some sort of mixing needs to be done to make it travel fully or not. Help would be greatly appreciated. Also if there is a post that you could point me to that has a step by step primer on the Ultra Stick programming, that is a little more explicit than the ones supplied with the plane, so I can make sure I have it 100% that would be greatly appreciated.
BTW The servos are plugged into the right ports on the servo.
CA
RE: Ultra Stick 60 & JR 8103
Hi Brent,
Danny has answered this question many times.
Just look down thru the pages of questions asked .
Good luck with You US 60.
Hope You have read some of the post on the plane
on what things that need to be changed with it.
Happy Flying ,
Hozer.
Happy Flying ,
Hozer.
Danny has a link for this combination.
Goto.....
http://horizon.hobbyshopnow.com/shar...ultrastick.pdf
And hopefully that will resolve your problem.
Goto.....
Check your sub trim values and make sure the sub trim values are low, as close to 0 as possible. It sounds like you are simply running out of travel on the servo. Feel free to give one of our product support techs a call at 877-504-0233 for further assistance.
