PCM 10 Question
PCM 10 Question
I purchased a used PCM 10 (Net - A110HZ). When I try to set wing type, it won't go into wing type display mode. Also, when I first turn it on, it has a helicopter in the lower left hand corner. Was I suckered into buying a helicopter only version, or is there a secret code to enter to convert it.
John
John
RE: PCM 10 Question
Hate to say it, but the HZ at the end of the NET number indicates that it is a Heli Mode Set. For Acro, you would need to get the FZ variant. Unfortunately the PCM 10X is either or and not both.
Where did you get it from and did you explain exactly what you wanted ??
If it was from a shop, then you should ( theoretically ) be able to return it.
[8D]
[8D]
