10X Battery Case
My Feedback: (9)
10X Battery Case
Danny,
I would like to replace my stock 10x battery with an upgraded one. Can I buy just the battery case to from Horizon, or do I need to buy the whole thing?
Any other suggestions?
Dan
Dan
RE: 10X Battery Case
That pack is only available complete, it is part number JRPB965. The only other option, which if there is any warranty on your system could void the warranty, is to just replace the cells in the existing pack.
TX
The cells are connected, but they have a pair of wire connecting it to the board in the pack. The internal pack is pretty much a standard 8 cell pack, and what I found worked very well is the Expert 1500 MAH pack. All you need to do it to remove the shrinkwrap (the pack is just a tad too thick to get the 10X battery container together with the shrink on) and solder it in in place of the old one. As a bonus, when I uncovered mine, I found that although it was sold as a 1500, the cells were actually 1650's!
This will cost you a heck of a lot less than another full battery pack, and if you are at all handy with a soldering iron (or know someone who is) it is no more than a 5-10 minute task.
- Tim
- Tim
