JR 649 receiver
My Feedback: (99)
TX
JR 649 receiver
Hey danny, is it ok to run 2-2200 li-ions packs into the receiver. they will be on 6 volt regulator's. that's almost 13 volts seems to be a pretty big load.
thanks
thanks
RE: JR 649 receiver
Actually if you run them in parallel, each plugged into separate channels in the receiver, the voltage will be the same, 6 volts. They do not get added running them in parallel. If you run them to separate channels, that should work just fine. I set airplanes up with 2 packs like that myself quite often.
