ES 539 servos for 72" Katana?
Hi All,
Will the JR ES 539 servos (4.8kg) be suitable for the control surfaces on a 72" Katana? These servos have plastic gears.
If they would not be suitable, what should I be looking for?
Thanks for any feedback.
Langfire
Langfire
RE: ES 539 servos for 72" Katana?
A nylon gear set should hold up ok in that size plane. For additional security you could install a metal geared servo, but nylon should work fine.
Hi Danny,
Thanks for your feedback on the nylon gears. Do you think that the 4.8kg will be sufficient torque?
Langfire
Langfire
If I have done the conversion right that would be around 66-67 oz in, if that is the case, the torque should be adequate for that size model.
