8103 Flaperon
8103 Flaperon
Hi Danny, Is it possible to when using flaperon to get the flap pot to only deploy the ailerons downwards. I am having trouble returning them back to neutral without going past this point.
Thanks Geoff.
Thanks Geoff.
RE: 8103 Flaperon
Yes, it is possible. Set up a program mix, I would use mix 3 or 4, mix flap to flap, rotate the knob in the direction you want to inhibit the travel, and enter in a percentage of -100%. This percentage will need to match the flap travel adjust value in the travel adjust function, so if it is not 100%, it will need to match it.
RE: 8103 Flaperon
Thanks Danny,
It worked a treat, you wouldn't believe how long I have tried to to get that to work.
Is there a book available which would help me understand better, using mixes as I haven't a clue how your solution works.
Thanks again geoff
Thanks again geoff
