JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 10X Mixing Question
Reply
Old 03-24-2004, 11:04 PM
KevinBarr
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 10X Mixing Question
Greetings,
I am setting up a BV Saber. I have the brake valve mounted such that the retract servo can activate it when the servo drives forward slightly more when the gear is in the down
position (pretty typical set-up). The problem I am having is I want to activate the brakes via the slider on the RIGHT side of the transmitter (AUX 3), but I can only get the slider to effect the servo when the gear switch is in the UP,or toggled toward you, position. I need to have the mix occur when the switch is gear down, or in the position away from you.
I cannot seem to get this to work..Any ideas?
Regards,
Kevin Barr
KevinBarr is offline
Old 03-25-2004, 02:34 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR 10X Mixing Question
What you will need to do, is set up an aux 3 to gear mix (if you are using the gear channel) press page, select the gear switch, press page again, and press SEL under master until it says ORIG. Then press page again, make sure the values are 0% in the switch position you want the mix off, then flip the switch to the on position, and enter in percentages as needed to get the throw required.
dsnyder is offline
Old 03-25-2004, 02:37 PM
KevinBarr
My Feedback: (27)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
Sounds close to what I was doing, but it was a late night in the shop..you know how that goes..LOL
I will start fresh when I get home. I think with a fresh set of eyes it will work fine.
Thanks for the quick response...
Regards,
Kevin
Old 03-25-2004, 02:39 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Please let us know if you have any further questions.
dsnyder is offline
