JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
6102 Throttle Cut
Reply
Old 03-26-2004, 11:58 AM
Square Nozzle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 6102 Throttle Cut
What does the range of adjustment in the throttle cut mode do? As I recall, the adjustment ranges from -38 to -121 or thereabouts. My throttle cut function works fine but I have not seen any change in the amount of throttle closure with varied amounts of throttle cut trim.
Square Nozzle is offline
Old 03-29-2004, 09:42 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 6102 Throttle Cut
Adjusting the percentage in the throttle cut function adjusts the amount of travel when you press the throttle cut button. The throttle cut will show the most movement when the throttle cut function is maximized, the throttle stick is at idle, and the throttle trim is all the way up. The throttle cut function movement decreases when you change one of these 3.
dsnyder is offline
