JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8103, re-asign controls
Reply
Old 03-30-2004, 10:08 PM
trioval00
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8103, re-asign controls
on the 8103H i am setting up my turbine / facet... in the heli mode the 3 way switch works, when i switch it over to acro, the 3 way switch does not work, i need to set up the 3 way for the turbine jetcat p80. can i re-asign the switch thru the radio programing? or do i have to run the jet thru the heli mode?
thanks for the help
mark
trioval00 is offline
Old 03-31-2004, 10:09 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 8103, re-asign controls
You can assign the switch to various functions through program mixing. With the heli system, you can assign the mixes to either the "normal" mode switch position, or the "stunt 2" position which in the program mixes in aircraft mode will be switch selections ELE>F or LAND.
dsnyder is offline
