JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Throttle Mixing
Reply
Old 04-03-2004, 05:44 AM
rossco
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throttle Mixing
Ive got a twin engine plane and I cant get the motors to run exact. I cant adjust the carby links either because they are in the cowl which is glued down. Ive got the new JR 6-channel X2610 transmitter and I was wondering if you can mix the two throttle servos together using another channel? I want to be able to individual idjust each engine from the transmitter. Or is there anyway of doing it at all. Any help would be good
Rossco
rossco is offline
Old 04-06-2004, 01:01 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Throttle Mixing
Yes, you should be able to use mix number 4 to use another channel for the throttle, provided that you have either channel 5 or 6 open. Just mix the throttle to one of those channels, and set the rates as needed. Your other option could be to use a matchbox, so that you can independantly adjust each servo through the matchbox.
dsnyder is offline
