652 Radio and Twin Engine mixing capability's
I read over in the twin engine plane section that the JR 652 radio will not work for useing two servos to run throttles for mixing both engines so as to "sink" the engine's together correctly. Also it was stated that the throttle trim for killing the engines will not work or only work for one servo. Is all this true ?????????? Im just starting a twin engine project and hate to buy a new radio just for it.
Thanks for any help.
Joe
Joe
RE: 652 Radio and Twin Engine mixing capability's
That is true, the 652 does not have any include mixes that would allow that mix to be set up and have the trim affect both. You could however use a matchbox to have independent adjustment of each servo.
