JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Antenna
Reply
Old 04-08-2004, 10:19 PM
lighthorse
My Feedback: (22)
lighthorse's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Antenna
I am looking at shorter antennas.
Does the Base Loaded TX Antenna,72MHz Part Number: JRPA155
give you the same signal strength or more or less.
lighthorse is offline
Old 04-12-2004, 12:55 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Antenna
It will result in the same range (approximately) as the standard antenna. It is a little shorter (total length is around 22"), and is also flexible. If using the antenna with a system other than the 10 series with the top mounted antenna, you will also need the base loaded adapter (JRPA156).
dsnyder is offline
