JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
XF631 with spoilerons?
Reply
Old 04-15-2004, 11:14 AM
Scoubidou
My Feedback: (17)
Scoubidou's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default XF631 with spoilerons?
Hi Danny
I would like to programm my TX XF631 to get the flaperons going ''up'' instead of going down when i use the channel 6 switch with my Extra300L.
I have tried the reverse flap option but i did not work because the ailerons go in full deflection (left goes up and right aileron goes down).
Is it possible to programm that radio to have spoilers?
Daniel
Scoubidou is offline
Old 04-15-2004, 01:26 PM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: XF631 with spoilerons?
Go to the travel adjust function, flip the switch to the position where you want the ailerons to go up as spoilers, and zero the flap channel travel. Then make sure there is a percentage in the other switch position, which likely would be around 100%. Now if the ailerons are moving as flaps, swap the channels at the receiver that the servos are plugged into. It won't affect your aileron direction, but will reverse the flaps. It will however also reverse the differential function as well, if you are using differential, and the differential is working backwards, you will need to reverse switch positions, and reset as stated above.
dsnyder is offline
Old 04-21-2004, 12:32 PM
Scoubidou
My Feedback: (17)
Scoubidou's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for tip Danny, it works now!
In the meantime, i ordered a new TX 8103T. I will keep the XF631 as a back up
Old 04-22-2004, 09:19 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good to hear in both cases! Let us know if you have any further questions.
dsnyder is offline
