JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
8103- can't use throttle trim on gear mix
Reply
Old 04-18-2004, 06:34 AM
jchumley
jchumley's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 8103- can't use throttle trim on gear mix
Hi Danny:
I have resolved all but one of my problems on my three engine plane. I have mixed the other two throttles to gear and spoiler. The only problem I have now is that the servo on the gear chanel does not respond to the throttle trim. THe throttle and the spoiler servos both respond correctly. Is there a way to make it work or am I going to have to live with it?
Perhaps the better question would be, if you had an 8103 and a trimotor, how would you mix the three throttel servos together? (don't say matchbox! I don't have room for another molecule in the fuselage)
Jeff
jchumley is offline
Old 04-19-2004, 10:10 AM
dsnyder
dsnyder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 8103- can't use throttle trim on gear mix
You need to use mixes 5 and 6 for your mix from the throttle channel to the aux channel in order for the trim to work. Mix 5 and 6 are inclusive mixes which will allow the master trim to also work on the slave channel. The other mixes will not. If those mixes are unavailable, your only other option is to use an item like the matchbox.
dsnyder is offline
Old 04-19-2004, 10:52 AM
jchumley
jchumley's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Danny:
I am sure I can re-assign the mixes to make it work.
Jeff
jchumley is offline
